Brand: Frigidaire Model Number:FFHT1425VV05 Main Symptom: Not cooling What happens & when: The fridge just stopped working the motor is not coming on and the fridge is not cooling
The motor you are referring to is it the compressor or the fan motor in the freezer? If it is the fan motor in the freezer, it may be bad, you can check for 120 volts going into it. The compressor as well should have 120 volts going into the start device mounted on the side of the compressor.
