The unit is producing a small amount of water on the floor in front of the unit. Several years ago the top support for the hinge bracket cracked. I used liquid steel to fix and reset the receiver in the door to reconnect the bracket on the unit to the door. Not sure if that has led to this issue. I noticed in looking at the door that the frig door at the bottom is not even with the freezer door. This is a two unit setup, with a frig and freezer side-by-side with a trim kit around them to give that “chef” frig/freezer look. At the top, the two doors are even. Can’t tell if the bracket at the bottom needs to be adjusted, but can’t tell if it can be adjusted. Also looks like the gasket is “sagging” a little on the bottom, but now much different than the freezer gasket. These gaskets have screws behind the main gasket to secure the gasket flange to the door.
Is the small amount of water coming from the insulated line under the fridge? Mine is and someone came out to tell me I have a sealed system leak. I bought these right before the pandemic and my freezer went on me 3 months after I bought them brand new. I had to run out and find a freezer during the pandemic. I had to buy a huge chest freezer,cause that’s all there was left. Now my fridge isnt going down in temperature and I keep getting water all over my floor.
