Brand:Frigidaire Model Number:PLES389ECG Main Symptom:F13 error code What happens & when:F13 error code displays when attempting to use the broiler. All other functions work correctly
Error Code (if any):F13
You will want to test the oven sensor to make sure that it is good. At room temperature, the resistance should be 1080 ohms and if you test it at 350 it should read 1654 ohms. If the resistance is wrong then replace the sensor and if the sensor test good then replace the control board.
