when i turn on oven set temp. igniter work but gas comes on very low took a while for it to burn right about half hour.just wondering which part to replace
Mike,
Is it anything wrong with the surface burners?
Make sure the gas shut off valve behind the range is completely open.
Very likely the problem is a weak igniter. You can verify it by measuring the current drawn by the igniter. If it’s 3.2 amps or less, replace the igniter.
- The oven igniter AP2150412
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE FGF326ASE Frigidaire/gas Range | AppliancePartsPros.com
