Frigidaire oven
oven does not work, i replaced the baking element and it still will not heat everything else works fine
what could this be?
Replacement parts for FRIGIDAIRE FEF365BWG Frigidaire/electric Range | AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316255311.pdf
When you say that everything else works I am assuming that the broil and preheat will work.
Check the wires from the bake element to the control board for continuity.
If OK, then probably the control board is shot.
