I Keep Getting Fault Codes F1 & F3 And I Am Wondering What I Need To Do To Correct This. Is There Some Reset Or A Way To Correct This.
F1 means the board is bad, and F3 means the sensor is bad. I would replace the oven sensor, because it is wired up through the board. You board could be bad too, but since it came up with the F3, it could just be the sensor. The part # is 316217002. Tom
