Frigidaire oven
I just replaced burned out oven element. All controls act like they are operating normally, but no heat. indicator lights come on. I checked the resistance temperature detector and it had right reading.
Does the cook top heat?
Nat
The cook top works fine.
Check your wiring going to the element and the control board.
I checked the wires. Ihave 123 volts on each leg. With the oven controls off, I have no voltage at the elements. With the oven controls on, I have 123 volts at each of the element terminals, both the bake element and the broil element.
