Frigidaire oven problems
I have a 6 year old frigidaire. The other day i heard a pop and the fuse blew. Now the oven and broiler do not get hot but everything else works. The clock, stove top and digital display all work. Is it possible that both element went at the same time.
Replacement parts for FRIGIDAIRE GSE3WZCCB Frigidaire/electric Range | AppliancePartsPros.com
Here is a wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316255329.pdf
Unplug the unit and check the wires to and from the control board, specifically L2 OUT and L2 IN.
If all OK then odds are the control board is toast.
Is a good idea to check the solder side of the board just to be sure it is not just a bad solder joint at the relay.
