Frigidaire Oven Not Heating
Frigidaire convection wall oven from 2001. It stopped heating in the middle of baking a cake and I have no heat since. The convection fan comes on and it clicks like it is working, but it is not heating. Both bake and broil elements tested fine and the thermal circuit breaker was not tripped. I replaced the control board and I still don’t have any heat. Any help is appreciated.
Did you check the power at the unit?
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug.
The unit may be hard wired so you would not have a receptacle.
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
[COLOR=“Red”]Be careful as 240 volts is lethal !!![/COLOR]
I checked it this morning. 240 to L1 and L2, 120 to those and neutral. Is it possible that the second board is also bad? That seems unlikely, but I’m not sure what else it could be.
[quote=denman;877415]Did you check the power at the unit?
If OK
If OK
[COLOR=red]Be careful as 240 volts is lethal !!![/COLOR][/quote]
I am not sure how you determined that the control board was bad but it is always possible that the relay board is the problem.
Also does the unit have a DLB relay?
That would also kill power to both elements.
