hi. My stovetop burners work but my oven does not.
When oven is turned on it makes “clicking” noises (from control panel) as it did when it was working but the elements do not heat at all. bake/broil it does the same.![]()
Pull the range out of the wall. Remove the rear panel and check the wires from the control board to the heating (Bake & Broil) elements.
If there is nothing wrong, replace the control board. It has to be replaced together with the overlay because it’s glued on.
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE CFEF320GSA Frigidaire Canada/electric Range | AppliancePartsPros.com
