Frigidaire oven, clock display does not work
I have a frigidaire range the top elements work however, the oven and clock etc does not work. What do you think is the problem and how do I go about repairing it.
Thank you.
A model number may help others help you.
What do you mean when you say that the oven control does not work re: no signs of life, temperature is off etc.
Does the oven light work or anything else that runs off of 120 volts instead of the 240 volts that is used for powering the elements.
The control board also needs 120 volts so if the oven light is also off it could be a power problem.
