Frigidaire Oven broiler not working
The broiler stopped working completely, I removed the element and it checked out good even though this is the fix 99% of the time, but this is my life :wink:
The oven stovetops and lower element work just fine, so I know the 240V current is there..
My next step was to check voltage at the broiler element, whoops, 120V one side, 0V other side…
Am I looking at a new control panel? $300 bucks
Any suggestions?
Thanks all…
Can someone help with my oven problem? thanks!
Parts for Frigidaire PLES389ECH Range - AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Lassomption/318271934.pdf
It is more likely to be the control board (clock/timer), item F20 in section 03.
