Model Number:? Main Symptom: My daughter has a refrigerator that came with the home she bought last spring and it has no model # sticker on it. Its a Frigidaire Professional that has a Model # ENl57C13DGH R-134a compressor (s/n: 00815), Prod Date: 20/34 and uses a ERFVSCCP Control Unit. Double door refrigerator with a bottom freezer. In the water filters place is a twist lock plug that appears to have been installed since it was new as it has "“Nov 18” I cannot see a part number on it and it is very tight within the housing to see it internally
That is actually a water filter bypass plug. Some people use the bypass if they already have whole-house filtration or simply don’t want to use a refrigerator filter.
Could you check the back of the refrigerator for the model/serial tag and send me the model number? I’ll need the full model number to properly identify the correct water filter if you’d like to install one.
I appreciate your response, Jeffery but I do not think you read my entire question, no model number is found on the refrigerator. I offered part and numbers found and also pictures in the hopes that someone more in the know than myself could guide me to the right conclusion.
