Turntable and light work intermittently as if a relay contact is open or chattering. Is this something I can repair?
What is the complete model number of the microwave?
[quote=Gene;783834]What is the complete model number of the microwave?
Gene.[/quote]
Model number is FFCE2278LS
Thanks,
autoclaveman
Check the wires and connections from the control board to the turntable motor and light bulb. If there is nothing then the problem more likely is a bad control board. Frigidaire does not provide any parts list or diagrams for this model.
Thanks Gene,
It seems like no matter what manufacturer microwave I buy, they only last a couple of years. Do you have any recommendations?
autoclaveman
[quote=Gene;784044]Check the wires and connections from the control board to the turntable motor and light bulb. If there is nothing then the problem more likely is a bad control board. Frigidaire does not provide any parts list or diagrams for this model.
Gene.[/quote]
Such microwaves are very inexpensive today. GE or Whirlpool is a good choice.
