Brand: Frigidaire
Model Number: LTF2140FS1
Main Symptom: Won’t final spin
What happens & when: Washer will fill, agitate, and drain properly but fails to do final spin.
Error Code (if any): E43
Parts or tests already tried: Door lock controller
As described above, the washer will fill, agitate and drain properly but when it attempts to do the final spin it fails. I have put the washer in diagnostic mode and it successfully does tests 1-6, but when it gets to test 7 (“The washer will fill and spin”) I get error code E43. If I try to run a quick wash I can see the washer fill, agitate back and forth, and then drain and then it fails when it gets to the final spin and it just quits. I tried to change that door lock controller but that didn’t fix it.
