Frigidaire light works, nothing else
I have a Frigidaire fridge in my garage that quit working.
It’s always worked great. Stored it in my shop for the last
3 months. Plugged it it a couple times to make sure it was
still working and it worked great. This time, plugged it in and
only the lights work. Fan don’t come on either. I took the
back plate off the bottom to look.
Wondering what the problem could be.
I’m mechanically inclined but when it comes to fridges…
forget it.
Wondering also if the temp in the shop could make it not work.
It gets pretty hot in there and today is around 100 degrees.
Worked great the last time though.
I really hope it’s something simple. can’t afford to have it
fixed or have to buy a new one or an expensive part.
Hope you can help…
thanks
Replacement parts for Frigidaire FRT21S6AWH Frigidaire/refrigerator | AppliancePartsPros.com
How long did you leave it plugged in?
Could be that it is in a defrost cycle.
It should complete defrost in about 30 minutes.
If not try turning the defrost timer (Item 23 in Section 3) cam to see if it will start.
There should be a hole in the cover to let you do this.
I did what you said and it works!
Thank you so much!
