Brand:Frigidaire Model Number:LFTR2045VF9 Main Symptom:FC & RC too warm What happens & when: Defrost heater works correctly in the defrost cycle. Once that cycle ends, the compressor & heater will run continuously. Full frost pattern on evaporator. Not frost build up, no door seal issues, evaporator fan works. Freezer bottoms out around 30° refrigerator bottoms out around 55°. I did order a heater with bimetaland the defrost timer. Is there anything else I should look at?
Error Code (if any):N/A
Parts or tests already tried:N/A
If the defrost heater is receiving 120 Volts AC, and the heating circuit is not grounded out when testing from the defrost heater wire connection to ground while the power supply cord is unplugged, the defrost timer would have a contact failure inside of the defrost timer housing. 5304526183 Refrigerator Defrost Timer | Genuine Frigidaire OEM In Stock
