Frigidaire Induction - one section doesn't work
Brand:
Model Number: FgIF3036TFB
Main Symptom: The front right induction doesn’t heat.
Only front right module doesn’t heat. When I turn on
  • it starts the internal fan
  • the LED shows “P” blinking (which, if everything was normal, happens when I don’t put a pot on a specific spot) even if a pot is on the spot.
What could be a problem with and which part I should purchase?
The front right induction coil would need to be tested for resistance to identify if it has failed or if the generator board has failed. With the power cord unplugged, the top panel would need to be removed, the induction coil wires disconnected from the generator board, and the resistance should be less than 1 Ohm. If the resistance is open, or more than 1 Ohm, the induction coil would be the likely cause of failure. 5304511268 Bake Element (Oven Heating), 1 | Genuine Frigidaire OEM In Stock
Thanks. This is what I found:
I attached the picture:
when I opened the lid, the black connector on the coil is burnt . The connection harness simply popped out, and the circuit board at that connection is also burnt. as well.
Should I assume that both the board and the coil need to be replaced?
If so, which models should I order?
The right generator board and the element would both need to be replaced to correct that. Here are links to each. (The name in the link may be off but the part numbers are correct)
Right front induction element- 5304511268 Bake Element (Oven Heating), 1 | Genuine Frigidaire OEM In Stock
Right generator board- 5304531890 Spark Ignition Module (Generator) | Genuine Frigidaire OEM In Stock
I pulled it back apart and noticed that the burners are not quiet the same. They both have the same part and revision number. The original burner was 4500 watts. the replacement is 3700 watts. Could this be the problem? FYI the part number you have listed above is the oven bake element, not the burner/
The name of the part is incorrect and we are working on getting the labels corrected. However, the part number is correct for the induction element and the link leads to the correct part number for the right front induction element.
