Frigidaire icemaker not making ice
I have a Frigidaire refrigerator with in the door ice and water dispenser. Icemaker quit making ice. First replaced the water filter. No ice. Second replaced the water inlet valve. No ice. Third replaced the icemaker. No ice. Checked all water lines and fill tubes. Nothing frozen or clogged. Don’t know what else to do?
Parts for Frigidaire FGHS2342LF3 / Refrigerator - AppliancePartsPros.com
Below is a link to a service manual.
I do not know if it is an exact match to your unit but it should be close. also the ice maker info in it is pretty good.
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;down=288
You will have to join the site and be logged in to be able to download it.
I would check the freezer temperature.
It should be in the 0 to 5 degrees F range.
It has to be cold enough or the ice maker will not work.
