On this side by side, the ice maker will not turn off, overfilling the bin. I’ve been turning it on and off manually with the power switch. It has a typical trip wire on microswitch; the wire swings freely and you can feel the switch click. Any help is appreciated!
I cannot find any info on the given model number.
Tried here and Sears.
Since it is just numbers I thought it is a Sears unit as they are the only ones that use just numbers.
Please check it.
Kenmore numbers are usually 3 digits, a period and an additional 8 digits.
Find your model number - AppliancePartsPros.com
Ice makers can be a pain to repair and often it is better to just replace it, depending on cost.
I looked again and found this number:
Electrolux PLHS267ZDB2
Thank you.
