Frigidaire Ice maker only making huge chunks
The past 2 days my Frigidaire ice maker has only been making huge chunks of ice rather than cubes. (and obviously don’t come out of the chute!) We pulled the bin out last to empty all the ice and there is now a sensor (or something) hanging down from the top. The silly thing now is starting to leak water too. HELP! Any advice!?
Parts for Frigidaire FGHB2844LF5 Refrigerator - AppliancePartsPros.com
I cannot help with whatever is now hanging down perhaps the parts breakdown will help you identify it.
As far as the huge ice cubes it could be that the fill volume needs adjusting.
Also there is a possibility that the water valve is not closing fast enough. To fix that you would need to replace the valve.
Please see the following for a service manual.
It is too big to download here so I had to use a third party site.
Unclick the Use our download manager and then download it sa their download manager may put software on your computer that you do not want.
Download Frigidaire French Door Service Manual.pdf
