Frigidaire ice maker not working
hi
please help
i just hooked up my ice maker but water does not go up to the ice maker. and if i manually put water in the ice maker it does not dispense the ice.
water does go to the sylinoid:confused: but does not go up to the ice maker and i did turn on the ice maker so i decided to put manually put water in the ice maker and i freezes it but does not dispence it. i do not hear any noice that its workding.
please help.:frowning:
what should i do? :confused:
why dont water come up to the ice maker and why does ice maker tray dont dispence the ice once its done freezing it?
Thank you for your help:( :frowning: :frowning:
Pull the face cover off the ice maker. With the ice maker on, run a jumper wire from the hole marked “T” to the one marked “H”. If you don’t see the timer immediately start to turn (very slowly), the ice maker is bad and needs tobe replaced. If it starts to turn, keep the jumper connected until it has gon about a third of the way around, then remove it. The ice maker should then cycle like it’s supposed to. If it doesn’t, replace it.
