Frigidaire ice dispenser not working
Ice maker works fine, but the dispenser no longer works. The water dispenser works fine though. When the ice dispenser is pushed, nothing happens. Thanks in advance for the help.
Parts for Frigidaire GLHS66EJSB0 Refrigerator - AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/240389633.pdf
And finally here is a service manual.
You will have to join the site and be logged in to be able to download it.
It may not be an exact match to youir unit but should be close.
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;down=288
What part would be the issue? Should I start at the auger motor and is there a way to check that or would it more likely be the actual circuit board?
[COLOR=“Blue”] Should I start at the auger motor and is there a way to check that or would it more likely be the actual circuit board?[/COLOR]
Cannot say.
I would start by ensuring that the auger motor is OK.
Check if it gets 120 volts when it should.
This may be difficult to do because getting to test points may be a pain.
Also double check that it is a 120 volt motor.
If it has voltage and does not turn then replace it.
You could remove it and then check for the voltage at the correct pins at the receptacle. This should be easier.
Note that if you click on a part’s description or picture a new page will open with additional info on that part. Sometimes a Q&A section and perhaps even a video.
