Brand: Frigidaire Model Number: GRFS2853AF4 Main Symptom: ER CE Error Code What happens & when: Error code continuously active, control/user interface board allows selection of ice but will not dispense ice
Error Code (if any): ER CE
Parts or tests already tried: Side-by-Side Refrigerator Control Board (Part Number: 5304530929), & Main control board (Part Number: 5304534600)
My Frigidaire GRFS2853AF4 is displaying the ER CE error code I have tried replacing the Side-by-Side Refrigerator Control Board (Part Number: 5304530929), & Main control board (Part Number: 5304534600). The new Side-by-Side Refrigerator Control Board would not power up with either the old or new main control board. The old Side-by-Side Refrigerator Control Board would power up with the new main control board but the ER CE code persisted with the new main control board.
Since you’ve already replaced both the dispenser/user interface board (5304530929) and the main control board (5304534600) and the ER CE error is still present, I would stop replacing boards and start looking for a communication problem.
On Frigidaire Gallery models, ER CE indicates a communication failure between the dispenser/user interface and the main control board.
Here’s the order I would troubleshoot it:
Perform a hard reset
Unplug the refrigerator (or turn the breaker off) for 5-10 minutes.
Restore power and see if the error immediately returns.
If it comes back within a minute or two, the communication fault is still present.
Inspect every harness connection
Disconnect power.
Remove the dispenser UI and unplug/reseat every connector.
Remove the rear cover and unplug/reseat every connector on the main control board.
Look for:
Bent pins
Corrosion
Loose terminals
Backed-out pins
Moisture around the dispenser board
Inspect the door harness (most likely)
Since the ice dispenser has stopped working and you’ve already replaced both boards, I’d pay very close attention to the wiring that runs through the top freezer door hinge.
This harness flexes every time the door opens and closes and is one of the most common causes of communication errors.
Look for:
Broken wires inside the insulation
Pinched wires
Green corrosion
Partially broken conductors that only make intermittent contact
Gently flex the harness while watching the display. If the error changes or clears, you’ve found the problem. Similar Frigidaire communication faults are frequently traced to damaged wiring in the door harness.
Check continuity of the communication wiring
With power disconnected:
Disconnect the harness at both the dispenser board and the main board.
Check each wire for end-to-end continuity.
There should be very little resistance (typically under 1 Ω).
Also verify there is no continuity between adjacent wires (no shorts).
Verify power to the dispenser board
If you have a multimeter, check that the dispenser board is actually receiving its low-voltage supply from the main board. A missing supply voltage due to an open wire or poor connection will also generate an ER CE fault.
Based on what you’ve already replaced…
My suspicion would be:
Broken wire in the freezer door harness (most likely)
Loose or damaged connector
Bent or corroded terminal
Incorrect connector seating after the board replacement
It would be very unusual for two replacement boards to produce the exact same communication error unless the wiring between them is the real issue.
One question that will help narrow it down:
Does the dispenser display still respond to button presses, or is it completely frozen with only “ER CE” displayed?
Does the interior dispenser light come on when you press the paddle?
Thank you for the quick reply. The dispenser display does respond to button presses but the dispenser light does not come on when pressing the paddle. I do not recall seeing any bent pins when replacing either board.
In step 2, you mentioned “Remove the rear cover and unplug/reseat every connector on the main control board.” It appears my main control board is underneath the unit near the front, requires opening the freezer to access. Is there another control board in the back somewhere I need to check?
Also, not sure if it helps, but in response to “It would be very unusual for two replacement boards to produce the exact same communication error unless the wiring between them is the real issue.”, the replacement side-by-side control/user interface board did not power up. I had to go back to the old/original board.
Sorry when I looked at the diagram I saw what I thought was a board but its just some kind of cover, yes yours only has the 2 boards you have already replaced. I am attaching a Tech sheet with a wiring diagram
