I have a Frigidaire FES365ESA (white) glass cook top range. I need to replace the glass top. Is this easy to do and can I get the part here?
Thanks so much!
You can get the part here, part # AP3874885.
Nat
I ordered the part this morning.. but I am still not how to install it once it gets here…
Thanks so much!
Terry
I’m not much help on the install part, more the parts research part. But if you look at the parts breakdown generally you can see how they go together. If you need the breakdown the searspartsdirect website has it where you can see it.
Nat
