Frigidaire Gas Stove/Oven
There is no ignition to the four top burners. Burners have gas and can be lighted by a match. Will replacing the “module”, Part # AP4374595, resolve this problem?
If so, how does one gain access to the part?
Hi.
Most likely it’s the spark module, there is a small chance that the spark switches harness is burnt.
It’s not very clear where is the module, I would check first the rear of the range. If it’s not there - then inside the cook top.
Here are the breakdown diagrams and Replacement parts for Frigidaire PLCS389DCB Frigidaire/gas Range | AppliancePartsPros.com
Thank you. Post the results.
Simon.
