Frigidaire Gas Range
One of the digits on display for clock, timer and temperature has burned out. If I flick it with my finger, it will return for a moment and then darken again. All the other digits other than the 2nd from the right are fine. For instance, instead of saying 350 degrees, it looks like 3 0 degrees. Any advice is appreciated!
You could check the board for the clock for bad connection, but chances are you will have to replace it to fix the problem.
Replace the entire board or just a part of it? Is this something my husband could handle or do we need to call a service company? About how much does a board cost? Thanks!
Here is the part for your oven.
Part Details - FRIGIDAIRE Clock/timer, part number: AP3853281
Easy enough to change.
