showin F10 code. I have replaced the RTD sensor and still showing same code. Please help:(
Hello Sholt115. If you replaced the RTD sensor, and the unit continues to give an F10 error code, it sounds like the clock assembly may be bad and will need to be replaced. Here is what the manufacture says about the F10 code. [FONT=ArialMT][SIZE=1][COLOR=#161616][FONT=ArialMT][SIZE=1][COLOR=#161616]
[LEFT]1. (F10 only) Check RTD Sensor Probe & replace if necessary.
If oven is overheating, disconnect power. If oven continues to
overheat when the power is reapplied, replace EOC. Severe
overheating may require the entire oven to be replaced should[/LEFT]
damage be extensive.
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT]Hope this helps.
AP4510792
