Frigidaire Gallery Refrigerator Control Board
Brand:Frigidaire Gallery
Model Number:FG4H2272UF
Main Symptom:Control Board failure again
Hi bsrourke, I’ve attached a tech sheet to help you identify and find the correct control board for your unit.
My control board # 5304531885 was purchased last April and installed. Everything was up and working again after the install. Today I had a 1 minute power outage and the same issue occurred. I have no lights to my water/ice display. Everything is working normal on the fridge except for this issue. I did multiple resets by unplugging the fridge with multiple durations. No luck. I spoke with someone there and he said that I needed to try this forum before any replacement part could be issued. If there is a fix please tell me. The person I spoke to said because there are multiple boards, it could be the display board. Since the board I ordered in April fixed the problem the first time I don’t want to be told it’s the displays board for $261 which you have in stock. Please advise what to do next?
The serial number is 1K95180810
There isn’t any extra number that you asked for.
The date of the fridge is 12/21/19
You can see a description of what happened in another reply
What is going on? Can you help me or not?
This is my information for my Frigidaire Gallery refrigerator. There is no pnc number.
Hi, a power outage can sometimes cause a communication lockup between the main control board and the door display/UI. Before replacing any more parts, I would try a complete reset and then check whether the UI is receiving power.
First, unplug the refrigerator from the wall. Remove the plastic cover from the top left door hinge and disconnect the wiring harness going into the door. Leave both the refrigerator unplugged and the door harness disconnected for a full 10 minutes. Then reconnect the harness securely and plug the refrigerator back in. Check whether the display comes back on.
Also, look closely at the display for a faint “Power Outage” or “PF” message. If you see one, try pressing and holding the Clear Alerts or Cube button for about 6 seconds to see if the control resets.
If the display is still completely dead and you’re comfortable using a multimeter, the next step would be checking for DC voltage at the door harness. This is a live-voltage test, so only perform it if you have experience working around energized appliances.
If the main board is not supplying the required DC voltage to the door, the problem is on the main-board/power-supply side or in the wiring. If the correct DC supply voltage is present at the hinge connector but the display remains completely dead when connected, that points much more strongly toward the door UI/display board or its wiring
