Frigidaire Galler Series dr code
Hello, thanks for any input..
My over under dryer washer combo has presented with some issues..
The dryer is my main concern..It failed to start, the dr code came on..and won’t leave. I took the dryer down, and cleaned it completely as new..not one spec of anything, tried resetting it , by unplugging, and plugging back in..to no avail.
Then I addressed what I thought might be the issue..the door switch..and while I was at it, I replaced one of the latches as it looked awkward..(bent)
 Still nothing but a *dr* code.. anyone have any ideas what my best track is ?
Hello,
Recall the error codes stored in the memory as described in the attached tech sheet and post the results.
Here are the breakdown diagrams and Parts for Frigidaire GLEQ2152ES0 Dryer - AppliancePartsPros.com
GLEQ2152ES0.pdf (291.9 KB)
