My Frigidaire FWS933FS2 Washer intermittently leaks on the floor during the drain part of the cycle (right after the wash cycle). I’ve checked the drain hoses and pipe, recently replaced the pump, and have not overloaded the washer or run an unbalanced load. Since everything else looked good, I re-leveled the unit and thought that had fixed the problem - I washed several loads of various sizes with the drain functioning normally, but it leaked out again today. It’s done this before on several occasions but is not a constant issue. Thanks in advance.
Is the leak a fair size puddle or is it a small puddle? Also, does the water cover the back and front of the washer, or is it on one face (back, front, or a side) of the washer?
The water comes from underneath and will drain out the entire tub if not shut off in time. I wonder if it’s the timer because I just ran a load with a different cycle and it looks like it worked without leaking?
If the water is coming from the bottom of the tub and not from the top, the timer and the pressure switch would not be a cause of failure. When the leaking occurs, is there water in the tray where the drain hose connects to the house drain?
