frigidaire front load washer won't fill with water
I have a frigidaire front load washer that quit filling with water. It won’t fill on any cycle, and I have checked the inlet valve, even tried a new inlet valve and still no water. I have researched and think it may be the timer, but I have also heard that it is rare for a timer to quit all out and not work at least on one cycle or more. Any suggestions??
Check the wiring and connections at the timer, but it sure sounds like the timer is the problem. Yes it can fail on all cycles.
