my washer started making a loud noise when in the final cycle (drain/spin) i investigated by removing the front panel…the water pump is in the front right corner and it clearly was making an awful noise…if i touched it…the noise would quiet…i have removed it and checked for debris that might get caught in that area…i found seven quarters and a dime..woohoo…then put things back together…i still have the noise but not as badly but it won’t drain the clothes/tub. if i put it back on final spin again it would sometimes pull all the water out then spin but i am now stuck with a soggy load that won’t drain/spin.
i thought it was that the dials were stripped and not recognizing the mode it was in but i tried a different wash cycle and it didn’t drain there either.
i’m thinking i need a new water pump.
if the wash load is to0 heavy with water will it likely be unable to go into the final spin cycle?
i look forward to your feedback as i want to get the part ordered today if possible.
thank you.![]()
