The last few months our side by side has been making a horrible loud noise, coming from the freezer. My husband took the freezer panel apart, and noticed that ice had completly jammed the fan that cools everything. Got all the ice out, and it was fine for months. Over the last 2 weeks, it has been happening every few days. Again, hubby takes the panel off, and removes all the ice built up on the fan, and its ok again. What is causing this, and can it be repaired? The fridge is only a few years old, and we paid a lot for it, and cannot afford another one!
Here are parts for this series, use the number 7 (Last digit) your number nine is probably too new for parts to come up on this system.
But if ordering be sure to provide the full model number as the parts people have access to more info that the on-line users.
Replacement parts for FRS26KF6EW9 models | AppliancePartsPros.com
Here is the tech sheet for this unit, it has the info on how to force a defrost cycle.
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/240389629.pdf
Sounds like you may have a defrost problem.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle (see the tech sheet) When the fans and compressor turn off, you are in a defrost cycle.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the Adaptive Defrost Board (Item 23 in Section 5) needs replacing.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 14 in Section 6) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 21 in Section 6) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost board is toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
Thank you so much. I am so irritated that this fridge is so new and we are having so many problems with it. We had an old plain top freezer, bottom fridge, and no problems for years. Got this one for the stupid ice maker Thanks again, I will have my hubby check it all tonite when he gets home, and let you know whats up.
Amanda
