Frigidaire FPRU19F8WF3 Stuck in sabbath mode
The refrigerator went into sabbath mode on its own. I could not get it to exit sb mode as per the Frigidaire manual. I also tripped the breaker and waited for 10 minutes before turning back on. Still did not exit sb mode. The refrigerator is cooling so I don’t believe the main circuit board is an issue. My guess is either the control panel button sensors or the control panel circuit board have failed.
In the parts list, the circuit board is part number 03-22 but I could not determine if it included the panel button sensors. Or do I also need part 03-21 get me the panel buttons and circuit board? Or is 03-21 just the plastic panel cover?
The cover 03-21 should have the boards and the shelf with touch assembly. Frigidaire 140130183225 Refrigerator Assy-Control Cover | Genuine OEM Part
For future reference - the control panel assembly was replaced and that fixed the problem. It took more time to remove the frig contents than it did to replace the panel
