Frigidaire FPBS2777RF0 making a clicking sound
Brand:Frigidaire
Model Number:FPBS2777RF0
Main Symptom:Making a clicking sound
Error Code (if any):None
Parts or tests already tried:replaced cooling fan last August.
Where in the appliance does the noise seem to be coming from? Does it sound like a fan hitting something?
No, it sounds like it’s coming from the bottom, center, back area. The clicking is inconsistent and irregular. I just replaced the fan last August. I cleaned and swept it all out at that time as well.
It just started yesterday. It’s making a clicking sound, similar to a switch clicking on and off. It seems to be fairly constant while running. It seems to slow a little when off, and sometimes will almost go away. But, later you notice it again. I just replaced the cooling fan last August, the old one disintegrated. This clicking sound started yesterday.
Clicking in the bottom, back, center could be the inverter board AP6277934. But if the machine is cooling properly, and only that clicking is going on, it’ll be difficult to identify an actual problem.
https://www.appliancepartspros.com/frigidaire-relay-5304512686-ap6277934.html
Could it be a compressor start relay. Is there one on this unit?
That is part of the inverter I referenced.
