Frigidaire FGSC2335TF9 noisy cycle
What happens & when: During one of the cycles it is very noisy. Can wake you up. Made a video but can’t upload *.mp4? Otherwise everything is running fine. When on other cycles it is relatively quiet.
Charles, Thank you for your question. The best thing you can do is to check to see if you can determine when the noise is occurring and if it is when the units icemaker is cycling, during defrost, Etc. What at the time is running or not running. With more information we would be able to assist with what may be going on.
Thanks for your response. I’m almost certain this is not the icemaker. I’m thinking it has something to do with the defrost cycle. How could I identify that the defrost cycle is on? If that is the problem - what is the probable repair?
