Frigidaire FGES3065KFD no voltage at bake element
Brand: Frigidaire
Model Number: FGES3065KFD
Main Symptom: no 240v at bake element
What happens & when: no heat from bake element
Error Code (if any): none
Parts or tests already tried: replaced relay board in back 316442112
240v at broil element OK. 14.1 Ohms
120v at convect element OK. 42.5 Ohms
0v at bake element. 21.9 Ohms
Bottom warming element not checked. (Don’t use)
Replaced rear relay board 316442112. Still no bake element voltage.
Suggestions for next steps/part to purchase
If checked at the bake element (with the oven set to bake and turned on) with a reading of 0-VAC, then check at the oven control at terminals P1 to P9 … if no power then the issue is likely the electronic control board. If you do have 240-VAC at P1 to P9 the issue is the wiring between the board and the element.
318550151.pdf (394.6 KB)
https://www.appliancepartspros.com/repair-help/ranges-stove-oven-repair-help
No voltage at P1 to P9
I replaced board and it works.
