Frigidaire FFBD2411NSOA won’t start
Brand: Frigidaire
Model Number: FFBD2411NSOA
Main Symptom: won’t start
What happens & when: it starts and then stops a minute later. Then when I open it there’s no water
Error Code (if any): none
Parts or tests already tried: I have tried starting it multiple times
If the unit is completely shutting down, check to make sure that the door switches are good and check to make sure that the drain pump is getting power which is the first thing it does when starting. If the drain pump is not getting power at this point then it would cause this issue and would be a control board.
Thank you so much! I checked and cleaned the door switches and now it works. My whole family thanks you :two_hearts:
