Oven temperature takes off; stove shows F10 code and beeps. You can turn the oven off but when you restart it the same thing happens?
Worth repairing or time for a new one? How to troubleshoot?
Hi.
First, check using the multimeter the temperature sensor’s resistance. You can do it at the control board 15 pin plug between pins 12-13.
At room temperature you should read about 1100ohm.
Replace if it’s off
If the sensor is good - replace the control board
You may need an overlay too
Here are the breakdown diagrams and Backguard parts for Frigidaire GLEF379DQG - AppliancePartsPros.com
Post the results.
Simon.
[quote=Simon / APP Team;800654]Hi.
Replace if it’s off
Post the results.
Simon.[/quote]
Simon-
The molex plug has no wires in positions 12, 14, or 15, unless I’m counting from the wrong end.
Hi.
You are looking at the wrong end. Look careful at the end of the plug, they should be marked.
Simon.
