Frigidaire electric stove
im having problems with my oven . first the bottom element went out then a few weeks later the bottom went out. should i replace both elements or should i replace the circuit board? does any one know?
Pull the range out of the wall. Remove the rear cover and check all wires from the control to the heating elements. Check both heating elements for continuity. Post the results.
Here are the breakdown diagrams and Replacement parts for FRIGIDAIRE GLEF379DQF Frigidaire/range | AppliancePartsPros.com
hi gene.thanks for answering. o.k i pulled it out and checked it. they both have continuity.
Sounds like the problem is a bad Electronic Oven Control. It has to be replaced together with the overlay.
thanks for your help.
