I have a problem with my oven. The top 4 heating elements are working fine but the oven itself isn’t. I check both resistance elements and they look fine, plus they have continuity. The temperature probe is working as well. I can’t find the thermal fuse, does anyone know where it is located?
Should I replace the entire control board?
Parts for LFEF3018LW - AppliancePartsPros.com
You seem to be missing the last digit in the model number so you will have to choose the correct unit in the Matching Model Numbers section.
See the attachment for the wiring diagram.
Note it covers LWA to LWD units.
[COLOR=“Blue”]I can’t find the thermal fuse, does anyone know where it is located?[/COLOR]
The unit does not have one.
[COLOR=“Blue”]Should I replace the entire control board?[/COLOR]
If the wiring from the elements to the control board is OK then odds are that the control board is toast.
