Frigidaire DW
Hello, Dishwasher will not start when button is pushed. Only the start button had been working for about a week prior. Not sure which part to replace? Control panel..console? Breaker switch is ok…any advice appreciated, thanks
Replacement parts for gld4355rfbo models | AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154580201en.pdf
And here is a service manual, your unit should be close to the ones in the manual.
http://frigidaireservicetips.com/pdfs/463_9.pdf
I am assuming the unit is totally dead.
Try getting into the diagnostics.
I would check that you actually have power at the unit with a meter.
Then that both door latch switches are closing.
Then confirm that the control board itself is getting power.
If the above is OK, disconnect the keypad from the control board to see if at least the digital display will fire up.
The problem can be either the control board or the keypad so it becomes a bit of a crap shoot as I cannot find a pin-out diagram for the keypad so that you could check it with a meter.
Hopefully someone else has a better way to troubleshoot this.
I would try the connector cleaning below.
Unplug the unit
Open it up
Clean the edge connector.
I have a 2-year-old Frigidaire Dishwasher GLD4355RFS0. All of the buttons (lights) are working on the control panel except for the Delay Start and Start/ Cancel buttons. I have replaced the latch and that is not the problem. I have tried a few of the R/T and Sensor tests and can get the motor running, but nothing happens when I press either of the 2 aforementioned buttons. I am not sure whether I should replace the control board or the control panel. How hard are they to replace? Any suggestions?
