Frigidaire dryer won't start
The start button does not depress and start. The button is sticking out further than normal. Do I just need a new switch?
First I would test the push to start switch and see if it faulty … After unplugging the dryer, remove the pannel behind the the controls and using a meter, test for continunity across the leads while at the same time depressing the push to start button … Also visualy inspect to see if the part is broken or cracked.
[COLOR=#800080]Back to Results[/COLOR]
Switch - start
Part Number: AP2138955
Made by [COLOR=#006600]FRIGIDAIRE[/COLOR] Our Price: $56.35
Compare at: $67.62
You Save: $11.27
In Stock
Order now and it will ship Tuesday
Quantity
