Frigidaire Dryer: Help diagnosing wobble sound after doing bearing replacement
Brand: Frigidaire
Model Number: FEQ332ES0
Main Symptom: rhythmic wobble sound
What happens & when: shortly after starting cycle, gets worse as time goes on
I have a Frigidaire Dryer (Model FEQ332ES0) that is making a rhythmic wobble sound after I did a self repair of the bearing and replaced the belt. It sounds really horrible when running for awhile. I found it challenging getting the drum positioned correctly when placing the door back on. I do see the drum rocking slightly back and forth when spinning. I made sure to level the unit as best as possible too. Any thoughts would be most helpful.
To hear: https://youtube.com/shorts/hFMvOXmMsyc
Note, when threading the belt I made sure to place the groove side down towards the drum. I noticed that bolt on the bottom of the bar holding the idle wheel was rather loose (I tried to tighten a bit). Also the bottom left door clamp broke so I have used duck tape until the part arrives.
It sounds like something might have gotten stuck in the felt seal of the drum. Removing the front panel and checking for debris would be the first check I would do.
I see a mark on the drum….seems to go all around the drum….what is directly below that line.
Idler pulley, motor bracket? Could be hitting the drum.
jeff sr.
