Frigidaire door
I recently tripped on my dishwasher door and fell on it. The door now looks as though it has bent a little and has pried up from the gasket. It still works okay, but leaks a little near the corner of the door and it’s noisier. Any suggestions?:frowning:
My daughter just fell on our brand new (around 2 months old) Frigidaire. Now the door sags when you open it, instead of stopping so the bottom rack is flat when you pull it out. It is model FDBB4365FC0 . When I go on the website for warranty info, it is all Canadian provinces, nothing for U.S.
The door doesn’t leak at all and the washer works fine. When I look at the door hinge, it is a cord attached to a spring and I don’t see anything obviously bent, or anything to stop its travel. I would like to find the service drawing so I can fix it but I cant find anything online. I think electrolux services frigidaire products in the US. If any one knows what part actually stops the door’s travel when you open it so that the door stays level and flat, PLEASE let me know! Thank You !
:confused:
I found this website for Frigidaire manuals. When you put in your model number and then click on the installation manual it will give you a pdf file for removing and replacing the door. (At least it did for mine.) I think that’s what I’ll try, just taking it off and trying to straighten it and then reinstalling.
:oSteenHensley
Oops! Forgot to give you the website!
http://www.frigidaire.com/support/manuals.asp
:o
