The circulation pump has the proper voltage, no blockage, so i need to know how to ohm it and what the ohms should be before i call it bad and replace it.
Thank you!
I do not have a spec on the winding resistance.
But if the motor rotates easily and does not run when it has 120 volts across it then it is toast.
[quote=denman;788419]I do not have a spec on the winding resistance.
But if the motor rotates easily and does not run when it has 120 volts across it then it is toast.[/quote]
That was my thought as well. Was just hoping to get the resistance spec to be 100% certain…that’s one expensive part for a cheap dishwasher! Might be better off just getting a new one!
Thanks for your reply!
