Frigidaire dishwasher
dishwasher starts and runs part way through the wash cycle then shuts off and all lights blink. we just bought a control module from appliancepartspros.com put it in and it is doing the same thing.
any sugguestions
Here is a tech shrrt
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Kinston/154547901.pdf
Seems to indicate a power failure.
Could be that the door latch or one of the door switches is not closing properly. So with the water hitting the door it opens, causes a no power fault.
Try a cycle then pull the door gently outward to see if you can create the fault. Or wiggle the latch withou actually opening it.
Turns out to be a loose wire at the junction box. Problem solved. I have a control module to sell now, if anyone is interested $75.00
