Frigidaire dishwasher won't run
My 4 year old frigidaire dishwasher won’t run…I had this issue before and it seemed that unplugging then plugging it back in did the trick. Now, when I unplug it the “heated dry” and “hi-temp wash” lights flash, indicating a power failure. I press “start/cancel” per the service data sheet then I can select my wash cycle. When I press start again nothing happens. The wash cycle light goes out and then, nothing. Any thoughts? Thanks in advance for your help.
Is there anyone on this board who might be able to help me??? Please?
The first thing I would do is check if the door switches are properly engaged when the door is latched. The model number you posted is incomplete.
