Frigidaire dishwasher won't power
I have a Frigidaire dishwasher that’s been working fine for a few years. I think it’s about 5 years old at this point. Tried to use it today, and it looks like it’s not getting power. Checked the breaker, don’t see any loose wires, etc.
Is there a reset switch somewhere, or an internal breaker?
Any help is appreciated…
remove bottom cover, there is a square aluminum box ,remove cover, the power wires are there, there should be two marrete conectors, carefully remove them, check for burnt wire, if you have a multimeter, check to see if you have 110 volts across these 2 wires, be careful these wires will be alive if breaker is good, if there is voltage the problem could be door switch in control panel.
Thanks, I’ll check it out…
I pulled off the square aluminum box ,remove cover, the power wires are there The two white wires were burnt! I followed the white wires up behind the door an everyting looked ok. If those wires are burnt behind the alum box what do you think I should look at now?
Thanks!
repair wires in box cutting away burned wires+test out machine
